Transmission gears grind while trying to reverse
Old 05-24-2015, 04:15 PM
Blackbird307's Avatar
Blackbird307
Blackbird307 is offline
Default Transmission gears grind while trying to reverse
I have a 1980 dodge ram van b100 and when I try to go into the reverse gear on my manual transmission, I can't, the gears just grind. For me to go into the reverse, I essentially have to turn the engine off, shift into reverse, and then start it up again. I can shift from reverse to any other gear without a problem.
It was working fine up until I replaced the clutch.
How do I fix this?
Thanks!
Quick Reply: Transmission gears grind while trying to reverse
