Passenger side wheel bearing
I'm new to the whole front solid axle and I have hub play. It's auto 4x4 any specialty tools I need or just pop of the calliper pull that cap off, snap ring and go from there. I know on newer dodges the rear axle you need a special socket with four prongs or so. And tips are appreciated
I have both hubs off I finally bought the socket I needed but the guy who previously went in there did not have it because the hub bolts were damn loose. I assume the first nut is to get rid of end play and then the second nut is tightened quite well? If you have a torque spec or and advice that'd be great
