Oil Pan Removal
RE: Oil Pan Removal
unless your rebuilding your engine, its not worth dropping that oil pan. when the drain plug on my 3.9 stripped out, guy i brought it to just welded on a race car lug nut and used a new pan bolt, cause he would of had to drop my front axle, hey is repair job worked so idc, nothing got into the engine so no worries on my end, but yeah, for a slight sludge build up if present, dont waste your time, if your really concerned run some of the lucas oil stabilizer in your next change, i put it in every change, comes out pitch black, but i know its removing all the crap too and each oil change lasts about 6-7000 miles so.. plus it keeps everything quiet on the inside and no dry starts
RE: Oil Pan Removal
ORIGINAL: f0x672
[sm=rant.gif]
RE: Oil Pan Removal
nah, i dont put **** into my truck... and if that stuff doesnt work, simply explain this to me, ive been running castrol gtx even since i got the truck, and it always had that dreaded tick, started using the lucas ****, no more tick, its not like its "hiding" anything if that tick is just a common issue on these magnum engines that doesnt pose a threat, please enlighten me
RE: Oil Pan Removal
found it heres what made me stop using it http://www.bobistheoilguy.com/images/lucas/lucas.htm
and this thread on another site is against it to...scroll down a little its a pretty long post by tempmaxman http://forums.maxima.org/showthread.php?t=167311
if you like it and it seems to be working for you im not telling you to stop using it just saying that i've heard about it foaming and that its not as great as it sounds.
RE: Oil Pan Removal
ORIGINAL: f0x672
RE: Oil Pan Removal
nah im not arguing with you at all pitkanen, just staing a point with imnothot
but hey you do what makes you happy, il do what i do, i mean yeah the lucas stuff and its advertising is blown way out of proportion, but that "eliminate dry start theory" is true from what i have experienced, hell the stuff is like molasses so i wouldnt doubt it will stick to anything inside that engine
