1999 dakota Front rotor removal
Old 10-07-2013, 08:35 AM
richfo's Avatar
richfo
richfo is offline
Default 1999 dakota Front rotor removal
I am having trouble getting the rotor off. Its a 4 wd does the rotor just come off after the caliper is removed? Or do I have to take the hub nut off. I am not sure what to do
Old 10-07-2013, 09:37 AM
sxrsil3nt's Avatar
sxrsil3nt
sxrsil3nt is offline
It just pulls off.
Smack it with a big hammer just make sure you don't hit the studs.
Depending on the rotor there may be a screw hole to push the rotor off though, I've never had to use that method.
Go with a BFH.
Old 10-08-2013, 09:09 AM
Robbadodge's Avatar
Robbadodge
Robbadodge is offline
One side on my truck is easy as heck to remove, the other side always requires the BFH. I still use a piece of wood to protect it, just in case the replacement is somehow bad.
Good luck!
Old 10-08-2013, 10:01 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
If never removed some have retaining clips on a stud or two look for them.
But a BFH is the answer
Quick Reply: 1999 dakota Front rotor removal
