Gas fill overflow on my 06 durango
#331
Does the following warranty info mean that this 2006 Durango, build date 09-22-05, VIN 1D4HB582X6F124883 would be fixed for free?
Your vehicle might be covered under a warranty extension, however. The dealer should check VIP to verify if a vehicle has a Warranty Extension. You could contact the dealer again, asking if the vehicle is covered for fuel spit back during refueling.
WARRANTY BULLETIN NO: D-12-07
SUBJECT: (X39) Fuel Tank Inlet Check Valve
(Fuel Filler Tube) - 2006-2008 MY Durango/Aspen
PURPOSE:
To announce an Extended Warranty for Fuel Tank Inlet Check Valve on certain 2006-2008 MY Dodge Durango (HB) and Chrysler Aspen (HG).
This warranty extension is unlimited time and miles.
Affected Vehicles:
2006 – 2008 Durango (HB)
2007 – 2008 Aspen (HG)
Note: This Extended Warranty Bulletin applies to HB vehicles with a naturally
aspirated gasoline engine built between February 1, 2006 (MDH 0201XX) and March 31, 2008 (MDH 0331XX) or HG vehicles equipped with a naturally aspirated gasoline
engine built before April 1, 2008 (MDH 0401XX).
WARRANTY BULLETIN NO: D-13-09
SUBJECT: (X48) Fuel Tank Inlet Check Valve (Fuel Filler Tube) –
2005-2006 MY Durango (HB)
PURPOSE:
To announce an ExtendedWarranty on the Fuel Tank Inlet Check Valve on certain 2005-2006 MY Dodge Durango vehicles.
This warranty extension coverage is unlimited time and miles.
Affected Vehicles:
2005 – 2006 MY Dodge Durango (HB)
Note: This Extended Warranty Bulletin applies to vehicles equipped with a gasoline engine built between December 1, 2004 (MDH 1201xx) and January 31, 2006 (MDH 0131xx).
PURPOSE:
Affected Vehicles:
PURPOSE:
Affected Vehicles:
#332
2006 dodge Durango gas tank
My 2006 dodge Durango doesn't like gas. It will only take penny before it splits most of it back out. After finding out the tank was leaking . Got the leak fix and found out that was how the tank was breathing. Once the leak was fixed the dodge doesnt like gas. So got a Replacement on the carbon cylinder. Still the same thing. Now they say I need a new gas tank cause I can't get gas to go in. Really Dodge? You know about 2005. You used the same tank on 06. This is a defect. Any updates?
#334
Gas tank reject gas/over flow issue
The gas tanks/fuel delivery system systems have a defect that can evidence itself in a few ways. Most of us that have had issues had overflow problems when pumping gas. That is to say, the gas spills out of the receptacle and overflows upon automatic shutoff. However, the mirror problem that many have faced is a type of gas fill restriction wherein the tank will not receive gas or fill properly, by shutting off the pump hose before gas can be filled. I have faced both problems at different times, as I have had three 2006 Durangos!
Both of these issues are due to a defect in the design or mis-manufacture of the gas tank system. They are covered in a technical service bulletin (TSB) issued by Chrysler. Find the TSB (it should be listed in this post), and read each and every post in this thread. Upon doing so you will learn of the problem, and remedies. I believe that Chrysler has a recall on the gas tanks, and will possibly cover the cost of the repairs. Again, that info should be in this thread.
Any Chrysler dealer that tells you that he/she isn't aware of the issue is either incompetent or lying. There is a TSB on the problem. Seek a new Dodge dealer. Trust me, I have seen several different dealers over the years, and I have seen quite a range of competency amongst them.
Good luck, and keep us informed. There are good people here to help!
#335
https://onedrive.live.com/redir?resi...int=file%2cpdf
#338
#339
1st visit to correct issue
Hello All, Just to give you an update as promised.
I took the Durango into the dealership for the replacement on the filler neck, and the other recall on the airbag.
they did the airbag, but after an overnight stay at the dealership the Durango does need the filler neck replaced, it is the problem which will be totally covered, but they need to order it and do not know when they will receive it.
OMGoodness, this truck is used for work.......so we are stuck with the inconvenience of spending over a half hour at the gas station to get the truck to take a whole $10.00......yay
#340
Glad to hear you are making progress. If the part you need is back-ordered, I would suggest that you get the specific part number (that you need) and call several dealers in the area. You may get lucky, and find the part. However, usually, Chrysler is pretty good about getting parts in. Your dealer should tell you when the part will be available, or at least give you a ball park estimate of availability. BTW once the correct part is installed your problem will go away. I'm on my 3rd "06" Durango Limited, and have been through the issue a few times. Keep us posted, and good-luck!
