gremlins
gremlins
hi been awhile..
I have some electrical gremlins i could use help with.
2007 hemi lmt.
i was driving down the road and i noticed in the information overhead console a RR Turn signal bulb out message so i pull over and check it and it seems out and i get the fast blink indicating bulb nfg..
So i drive to parts store to get bulbs and i notice while turning right into parts store that the turn signal works properly.. so i buy the bulb so i have it.everything works fine for a few days and it happens again. but after a little bit wala again it works fine, i chabge bulb since i had it works fine a day or two later same issue
this is only passenger side blinker and is quite intermitent any ideas ??
2007 hemi lmt.
hi been awhile..
2007 hemi lmt.
2007 hemi lmt.
I'm sorry to hear about your turn signal issues.
With the bulb replacement not resolving the issue, as @Twmays has stated, an issue with the relay or wiring may be present. In the event of a defective bulb or wiring, the system is designed to flash at a fast rate to notify you an issue has been detected.
