2nd Gen Intrepid 1998 through 2004 Intrepids
A Little Help, Please and Thank you. 2001 Intrepid P0202 code
Old 09-12-2012, 02:35 AM
djrnewcastle's Avatar
djrnewcastle
djrnewcastle is offline
Exclamation A Little Help, Please and Thank you. 2001 Intrepid P0202 code
Went out and started my car the other afternoon. all of a sudden my engine light comes on. that never happened. scanned it and got the codes. erased the codes and started engine again. 202 came on. drove it about a mile. checked the codes again and got the extra codes. Any quick fixes? I don't drive far. a couple of miles a day but I def. don't want my car to stop running. Can't afford for that to happen. Any Help would be appreciated. Thank you
Old 10-08-2012, 10:10 AM
Cblanning22's Avatar
Cblanning22
Cblanning22 is offline
Is it giving you any problems at all?
Old 10-09-2012, 08:27 PM
djrnewcastle
Well, it's running on 5 cylinders instead of 6 and running a little rough. And it's a 3.2L 2000, intrepid. Apparently I hit the wrong one.
Old 10-10-2012, 09:28 AM
kurts2's Avatar
kurts2
kurts2 is offline
Inspect the wires to the injectors...mostly #2 as that's the slow one. You could run some sea foam in your gas and see if it clears it up. Next steps are a bit harder. Try the cleaning...sea foam works miracles sometimes!
Quick Reply: A Little Help, Please and Thank you. 2001 Intrepid P0202 code
