Last edit by: IB Advertising
Browse all: Electrical System
- Dodge Ram 2nd Gen How to Reset Check Engine light
Step by step instructions for the do-it-yourself repairs.
How can I reset the check engine light?
I had no battery problem. I was a transmission problem. It don't apply to this thread. From an eariler conversation on another thread. So since knowledge is power, my 2002 2.7 xmission decided not to play anymore when the xmission was changing between 1st and 2nd gear. Lots of metal on metal sounds resulted (sorta like a NASCAR crash) Stuck in 2nd gear. Bla bla bla....After it was rebuilt, it required a "flash" (a technical term the service tech used) to be programed again. That's about it!! Hope this helps....
hey do you know where is the trans sensor on intrepid 2000 engine 2.7??? n are they easy to remove?>?>>????
