Oil catch can?
1. Catches oil from the PCV valve on it's way into the intake.
2. Keeps oil out of the intake, and subsequently, the top end of the engine (and intercooler/supercharger/etc., if you have one).
3. Yes.
3. Yes.
Some chemical resistant line, a couple of barbed fittings and a mini air compressor filter like this one: http://www.homedepot.com/buy/tools-h...ter-61421.html
Connect from the PCV valve to the filter and then back to the intake. On one of the cars I put the filter on, I glued the bottom to make sure nothing would leak out (a bit different when it's water from a compressor and not oil from an engine, lol).
Your line will probably be something like 3/8"
