Ahh, so you're the one who caused all this global warming? Just kidding! I'd say you need the upstream 02 sensor since the computer uses it to adjust the air/fuel mixture. The downstream sensor will serve no purpose wtithout a cat, other than turning on your CEL. I've seen a gizmo sold on the net that you can install on the sensor to keep the light from coming on, but I have no idea if it really works or not.
Ok thanks alot. I just put a brand new upstream o2 sensor in and the light came back on for no signal from downstream o2. Also I have a cold air intake and heavy rain affects the way the car drives...any way to keep the water/moisture away?
