Accelerating Problems on 2000 LX
Hello all. I have a 2000 Neon with an accelerating problem. My issue is taking off from a stop I can barely give gas or it bogs down. I am litterly feathering the gas from a stop. If I keep the RPMs up the car will run well enough. When I come to a stop I need to take the car out of gear or the RPMs drop.
If I running too many things in the car like defrost or heater it gets worse.
Coil pack, plugs, wires have all been replaced. Any suggestions?
I would check the IAC, crank and cam sensors too just to discard something wrong with them.
Are you using the OEM copper spark plugs (Champion RC9YC)? Iridium ones are not recommended with our Neons.
Hope this helps.
