04 neon wire id
Are you sure that's the color? I don't see a BK/OR wire in the fuse box on the wiring diagram. The only BK/OR wires I can find (right now anyways) on the car period that aren't grounds are on the ignition switch (pin 8, ignition switch output [run]) and on the instrument cluster (pin 5, VTSS indicator driver). Mostly though, a BK/OR wire is a ground wire on the Neons, so it would make sense that it wouldn't have power.
Going through the diagrams a bit more, it looks like that BK/OR ignition switch wire runs from the switch to "circuit breaker #1" in the in-car fuse box and fuses 6, 7 and 8 in the PDC (under the hood fuse box). CB #1 goes into TN wires that run to the power window switches. Fuse 6 goes to four switches and a sensor. Fuse 7 goes to the blower motor. Fuse 8 goes to the airbag control module.
It looks like the in-car fuse box gets it's power from a RD/WT wire from the PDC (fuse 3), which goes to fuses 13-16, which would be the second row in that fuse box...
Other than that, you can take a peek at the diagrams. Link is in my signature (FSMs). Been looking at diagrams for half and hour now. My eyes are tired of all the little lines, lol.
