View Poll Results: What kind of tuner are you using?
Super Chips
25
30.12%
SCT
38
45.78%
Hypertech
6
7.23%
MOPAR Performance PCM
8
9.64%
Other (Post it)
6
7.23%
Voters: 83. You may not vote on this poll
Tuners
#22
ya, im actully gonna give my superchips to my stepdad when i get a SCT from hemifever. =)
FI airgap, 21# or 24# injectors, 4.10 gears, shorty headers, SCT... whats next? haha.
#23
I know I am a bit behind on this reply, but you do realize that your stock injectors are 23.2 lbs, right?
#26
on
CM
#27
What's next? I'd pull the OEM PCM garbage out along with all their cheap sensors and install a complete engine management system along with a new LED cluster or flat panel display in the cockpit for real-time monitoring and unlimited data logging of ALL sensors plus additional sensors that were not included. Monitor the output of each cylinder and custom tune EACH cylinder vs. just using one limited tune based on OEM design and a tuner. Install a whole new fuel delivery system and trash the OEM junk, then, add in a whole new ignition module that controls the timing far better than OEM with total control PER cylinder, add in a fuel controller and a hi-level fuel pump, rip the engine out and drop in a new hi performance motor, new Hi-accuracy CAM and CRANK sensors that replace the OEM junk and then compare that to the OEM limited system that's tuned now with SCT. SCT is a starting point but, you can take it miles further from where you're at now.
CM
CM
on an unrelated note, how do you like your JBA's? I have a set for my 408 and was just curious...
#28
on
CM
#30
Hey guys, got a 96' 1500 w/ 5.9 auto.
Don't think anything has been done at or around the pcm. What is a death flash? What can I do for gas mileage and efficiency, to my pcm?
