DIY - How to Eliminate a CEL after Removing a Catalytic Converter
Old Apr 30, 2008 | 10:43 PM
HammerZ71's Avatar
HammerZ71
Thumbs up DIY - How to Eliminate a CEL after Removing a Catalytic Converter
This trick has been around for a while. All that is needed is two sets of spark plug non-foulers, available at any auto parts store for about $5 a set.
I did this on my last truck as well as a friends and it worked perfectly. The pics are not mine, they are "borrowed".
Spark Plug Non Fouler as packaged: Purchase the size that matches up to your O2 sensor. The last time I did this, I had the clerk take an O2 sensor for my friend's Chevy out of a box to match up.
You need to increase the hole size in one of the non foulers from each kit to 1/2" using a standard drill bit:
Screwyour O2 sensor into the modified non fouler:
Screw the sensor & modified non fouler into the un-modified non fouler:
Install:
This moves the sensor out of the path of the exhaust to where it is cleaner & cooler than in the direct path. The PCM is fooled into thinking the cat is still there, doing it's job and that everything is just fine...
123abc
