KANDUCO Sweet Tooth Grill...almost legendary
#22
#23
That was also my dads first thought as well. He said I should paint the honeycomb....I on the other hand was thinking about ordering some factory dodge black paint from PPG and color matching the grill inserts. I think it would look good and give it more pop cuz the whole background is chrome. I'll think about it though, not for sure yet..
#24
#26
So yeah if I do paint it matching black, I will take off the teeth for prep and paint of course. Hit with some 1500-2000 grit sand paper, then hit with some special primer for plastic. Then onto 2-3 base coats, and will finish of with a few coats of clear. *one of the teeth has a slight hair line crack, how would I repair before paint? PLZ don't tell me to use caulk...so lame. Ideas Lamarie or someone?
#27
One of the teeth on your Kanduco is cracked?
Has it busted the chrome foil on the front? If it hasn't, I would go to your nearest Oreilly's and in the back of the store there with the rear view mirror glue and the JB weld should be a small tube of glue looking like super glue. It's called something like plastic super glue or some such. I would apply a thin film with a small brush to the back side (where I assume the crack is) all around the crack. That should at least prolong the crack from expanding or worsening.
Normally I would say to use some body filler, but I feel that in that application, you would mess up the fitment of the piece.
This is all assuming that I assume correctly, and should I not assume correctly, please tell me where I assume wrong. LOL
#29
#30
