Oil sending unit
RE: Oil sending unit
its on the back of the block, behind the intake, throttle body, and air filter. its about the center of the block, just to the passenger side of the distributor. it helps if your arms are 6 feet long. it mounts vertical like this with a wire plugged into the top.
http://www.autozone.com/N,15300134//...eResultSet.htm
[IMG]local://upfiles/38819/498ADA3E092041929A6937A36B550C5F.jpg[/IMG]
well i feel really dumb. i did not have any problem with me sending unit or pump. i was about 2 and a half quarts low! yea i know.....
i checked the leve when this started happening but the truck had just been running so it was dificult to read the stick, but i saw oil so i thought it was fine.
so last night for ****s and giggles i checked it since it had been sitting for a couple days. NO OIL! awesome. so i bought some a filled her and now it runs fince with no idiot lights! i guess my plenum gasget needs a changing right, thats where these motors are know for loosing oil? everything i can see on the motor is dry so im guess its an internal leak. i hope autozone excepts return of the oil sending unit!
