Location of Bank 1 Sensor 2
Hi,
I have a Dodge Ram 1500, V8, 318. I did some searching about an error code p0138 showing that Bank 1 Sensor 2 was having issues. I found a post saying that it is on the left side behind the cat. The problem is, I located that one but the wiring harness plug is not the same. (Possibly wrong one from the dealer) and I looked further and I cannot locate the other 2 o2 sensors. Shouldn't there be one on each of the manifolds? The only 02 sensors I found where the one fwd and one aft of the cat.
If I understand what I found on here, the P0138 code indicates the faulty one is on the left side behind the cat. Is that correct and are there only 2 02 sensors on my vehicle?
Thanks for any help you can show me.
Coben
Reference for O2_sensor_locations
Coben
