My Truck won't stay running without throttle
Old 02-24-2009, 11:58 AM
Little_Blue's Avatar
Little_Blue
Little_Blue is offline
Thanks for all the suggestions guys, it ended up being the battery dropped a new one in and its running like a boss now.
Old 02-24-2009, 06:36 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
glad you got it running.
i'm going to guess at what was happening... something in the pcm and sensor circuit is probably expecting a voltage signal based on a 12 volt baseline. a bad battery with one or more dead cells, is registering about 11 volts or so. you manage to get it cranked and it runs. the alternator is pumping in voltage thats just getting sucked into the black hole of the battery. a key sensor, maybe the tps or iac, gets a reduced voltage signal, which just screws up everything.
Old 02-24-2009, 07:44 PM
TMS Bill's Avatar
TMS Bill
TMS Bill is offline
Sounds right but shouldn't the alternator set the baseline on a running engine? If its output is lame (squirrely voltage or slipping belt) that would explain why it only happens at low engine speed. A revved up weak alternator will put out higher voltage making everything work right.
I've got a sneaking feeling we've not heard the last of this.
Old 02-24-2009, 10:02 PM
dhvaughan's Avatar
dhvaughan
yes it should. a properly working alternator should energize the entire electrical system to about 14 volts. but several people have posted this problem over the years, a low voltage condition is the only thing i can think of.
i don't think its the pcm reset, because that usually fixes problems, not cause them.
and then when they replace the battery - poof its fixed.
here's one last reason why i think its a low voltage condition. have you ever tried to jump another vehicle, and you hook up the cables and the other vehicle just clicks... and so you jiggle the cables around and reclamp them several times - clicks. so you crank you truck and rev the motor - still clicks. so you rev the motor for 5-10 minutes and it still clicks. the other vehicle's dead battery just acts like a black hole of electricity. and after you get tired of screwing around you go buy a new battery and everything works fine.
i'd bet that if he was to check voltage on his dead battery with engine running, (that somehow, idk) it would not read 14 volts from the alt, but would read low.
Old 02-24-2009, 11:29 PM
IndyRamMan's Avatar
IndyRamMan
IndyRamMan is offline
lol, if its not the computer thing its the idle air motor.
Old 02-25-2009, 09:47 AM
Little_Blue
My alternator is good, so now its time to start saving money. Then move on to the next repair. lol It's a never ending battle but some how I find it worth it.
Old 02-25-2009, 12:28 PM
96RamSLT's Avatar
96RamSLT
96RamSLT is offline
+1 hes hooked
Quick Reply: My Truck won't stay running without throttle
