hub nut size questions
Old 07-28-2009, 12:22 AM
01DodgeRam1500's Avatar
01DodgeRam1500
01DodgeRam1500 is offline
Default hub nut size questions
so from what i've read the nut size for the front hubs on a 2001 4x4 is 1 11/16 but this does nothing for me as i have a 4x2. i went to the dealer and they pulled my VIN and gave me a hub nut based on that VIN. i measured the nut with a tape measure and it was about 1 5/16 is this supposed to be right? like i said i've found nothing about a 4x2 hub nut size.
Old 07-28-2009, 10:02 AM
01DodgeRam1500
anyone?
Old 07-28-2009, 10:08 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Why don't you just try it? A 4wd uses the large one and on some later models the 2wd uses the same hub bearing assembly as the 4wd. And some 2wd's have the traditional inner/outer replaceable bearings. You are just going to have to look.
Old 07-28-2009, 10:09 AM
Aubrey's Avatar
Aubrey
Aubrey is offline
I'm not sure. I need to find out for mine as well cause I have a bearing that needs to be replaced. I think a search on bearing install might find something but haven't looked yet.
Old 07-28-2009, 10:16 AM
zman17's Avatar
zman17
zman17 is offline
Well yours has the hub bearing assembly, along with the 1 11/16 nut, The OP's could have either.
Quick Reply: hub nut size questions
