Buzzing sound under the hood when accelerating
could be your WP shaft that hold your fan is out of true and on it's way out.. inspect your shroud for signs of wear/impact/rubbing from fan.. check fan blades themselves..
could be your harmonic balancer is giving up the ghost.. the nylon bushings wear and you get a wobble.. I 'spect it could first be noticed on revs..
does it happen when you are sitting still revving or while your moving only? that knocks a good bit of the questionable areas out by itself..
Only moving.
