What adapters do I need for the pressure tester? Looks like I can use a male fitting like on the fuel rail with a Tee and some fuel hose. Just need to find the male fitting
You can use a simple vacuum gauge to check exhaust restrictions. If you have one , hook up to intake and should have 17 to 19in on gauge. Increase rpm's and watch needle, if it does constant drop, then you have restriction, likely the cat.
unplug the O2 sensors, see if that does anything. at the least, it will tell you if your check engine light is functioning properly. Otherwise, if it helps then you may have some wiring issues if you find that your sensors are testing out as functional and within specifications.
check your timing! I met a dude who did everything and then some until he found bent valves as a result of a timing chain gone bad..
I have run the truck with both O2 sensor and TPS disconnected and the check engine light came on with proper codes. Thanks for trying. My next move will be Vac gauge when I get some time off.
