How to test IAC and throttle body sensors...
Old 07-17-2014, 12:25 PM
jmhd1989's Avatar
jmhd1989
jmhd1989 is offline
To reset the PCM, just disconnect the battery for five or ten minutes.
If it maintains a higher idle when cold, and gradually comes down as the engine warms, or, immediately comes down if the engine is already warm, things are working as they should, and I wouldn't worry about it.
If you are stalling when putting into gear, or changing direction of travel, that is a problem..... Mine sometimes does that when it is cold out, but, now, in the warmer weather, it seems to be running just fine..... See if the problem repeats itself when it gets cold again. (not in a hurry for that....)
ok so when i installed the new IAC i disconnected the ground so that should have reset the pcm at the same time as install. awesome thanks once again man
Old 07-10-2018, 10:57 PM
JC2000's Avatar
JC2000
JC2000 is offline
Did replacing the IAC and TPS end up solving your problem?
Quick Reply: How to test IAC and throttle body sensors...
