dang dinger
dang dinger
i may have asked this before and i have done some searching. but everytime i open the driver door, ding ding ding ding ding. no key in ignition. no lights on.
i have pushed the knobby thing in multiple times, ( yes it stops when i push in)
No i wont remove the buzzer as its tied to the intermittent wipers, (dont ask)
trust me, it is tied to the intermittent wipers.
the dinger is inside the CTM, and the ding is the same ding as "hey you left your lights on", and "hey this gas guzzler is low on fuel".
simple solution -
remove the knee panel and the covers from around the steering column.
unplug the 2 wire connector attached to the ignition switch.
--no fuss, no muss, no downside--
simple solution -
i'm guessing his sensor at the ignition switch is bad, falsely telling the pcm that the key is in the ignition. unplugging that might stop it.
--or, he might have a short in the wad of wires at the tilt wheel knuckle, involving that "key in ignition" circuit.
^this is a good mod for anyone (like me) that likes to open the door with the key in ignition and not be bothered by the dinger.
