Performance Chip
Performance Chip
So I am thinking about buying a performance chip for my truck. Problem is when I try to find one online they just seem too good to be true. You got a lot sites trying to sell these chips that will supposedly add 50-80 horsepower and add 4mpg all for 60 bucks. Then you have a couple of other sites that seem a bit more legit but I'm unsure of cause they claim to gain you up to 25 horses and its supposedly all a matter of plug and play and 250 dollars.
My question for all of you is this. Are performance chips worth it (assuming you buy from a legit dealer)? If they are worth it how much power do they really typically add and where is a legit site I can buy one?
The chips for $60 bucks are a sham and the ones for $250 are more true but aren't really worth it either. You're better off to get a SCT tuner from someone like Hemifever. This will reprogram your PCM which will really work plus get rid of your death flash and other factory junk that isn't needed or doing your truck any good.
Read this thread: https://dodgeforum.com/forum/2nd-gen...questions.html
Never even considered the tuner kits before. I've never used one before though or know much about them. I'm assuming an SCT Tuner basically accomplishes the same thing as having a shop tune your truck for you? Also having never used one before how easy is it to use for a first time user? Is it pretty straight forward or should I just let someone who knows what they are doing do it?
Here's a good one to start:
https://dodgeforum.com/forum/2nd-gen...22-tuners.html
and:
Yes a tuner does what a shop would do for you. Since you are stock your receive 3 tunes on the tuner and you pick which one you want to use. You install it and when done unplug the tuner. If at any time you add performance parts to your truck you contact Hemifever and he will write you a new tune and email it to you. It costs $150 I think if you already have the tuner to get extra tunes. Any updates you need can be emailed to you and then you just install them onto the tuner. Never have to send the tuner back or anything.
