Hard to Steer
#41
Something else just occurred to me , if the "over the top" adjustment on the steering gear is set too tight , you would have the same issue at idle . I bet it's the issue . It's quite common to see people attempt this prematurely (especially in the jeep world) . Not saying you did it , but , odds are , someone did along the way . Guess what ? It also causes pump failure if too tight . That would cause the restriction issue I mentioned previously . My advice is to back the adjustment off 1/4" to start . Doesn't take much
#42
I know it was asked once before, but how is the belt?
How many times did you go lock to lock to bleed the air out of the system? Some people have reported needing to go through 45-50 lock to lock sequences to full bleed all the air out.
If your power steering did not have this issue prior to changing the pump, I'm hesitant to see any adjustments done to the steering gearbox personally.
#43
Most boxes I have seen bad leak on the lower output shaft from play . They all have play , so a brace is recommended to keep them good . I just ordered mine today . Ram one on my 07 3500 . Loved it !
If you don't think it's ever been touched , I can't say I would be surprised to know one slipped through just a little too tight . Just mark it as it sits and put it back if it doesn't help . I think it's worth a shot myself .
#44
I do have output shaft seal leakage. I barely ever top off fluid. It doesn't lose much. I believe that is from the terrible play I have in my steering components. I will see about uploading a video of the linkages and how they maneuver. When it's up in the air however they do not bind at all. And all play is from pitman arm away from gear box. No play in my wheel to shaft or shaft to box or box to arm.
#45
#46
That's why I need to do a vid it's hard to explain. All the rods I can rotate on the joints, but I thougt that would have to for suspension travel song the steering connecting rods. But should they be able to move by hand?
#47
Here's an exploded view of a tie rod end, it's a ball in socket design. What you're looking for is any looseness in the fitment of the ball in the socket.
Hope this helps, let me know.
#50
Given this , I would have to point more towards the box being worn . Not many leak fast but the leak is caused by excessive play on that shaft
As for checking TRE's , they need to be loaded to check them properly . "In the air" doesn't work period . Weight on the wheels , have someone motion the steering wheel from 10-2 and look at each joint with a flashlight carefully . If you see anything visually , place your hand on the joint so it doesn't pinch you with the movements , and you will feel any clunks easily .
