Rear Driveshaft U-Joint Question
I bought a 2000 Dodge RAM 2500 4x4 as a project truck for me and my son. Doing a lot of maintenance work that had been neglected. Anyway, the front drive shaft u-joints were rusted bad, so I decided if I'm going to replace them, I might as well replace the rear as well.
Today we pulled the rear driveshaft out and one of the u-joint caps just slides in/out of the yoke by hand, and no press/tools needed. The cap on the other end of this u-joint was pressed in. After removing the u-joint I tried out my replacement u-joint cap and it too will slide in/out completely freely.
That being said, my question is this: I'm guessing that this means I have to buy a rear driveshaft as I know the caps are supposed to be pressed in and I'm thinking that having 1 u-joint where one of it's caps can slide in/out by hand will only spell trouble for the future.
Before I buy I knew rear driveshaft, I wanted to through this situation out to the more experienced mechanics here and get their thoughts.
Thanks in advance! cal
