Just used Mopar Combustion Chamber Cleaner (pics)
RE: Just used Mopar Combustion Chamber Cleaner
Ok little update:
So far (2 days later) the only thing I have noticed, I think, I'll have to check it a couple of more times, is that it smoothed out the idle of my truck. When I would start it up and let it idle, about 15 seconds into it, it would seem like it would bog down and rpm would go down a bit, but it seems better now. No performance gains, probably because my 285 tires with 3.55 gears are blocking any slight increases I might have noticed. Mileage, I just filled up today and calculated 11.4 but that is from October 30 so not much time for the cleaning to have been a part of it. Next time I fill up I should get a better mileage reading, I have done mopar combustion chamber cleaner, 1/2 a quart of marvel mystery oil in the gas, and 2 chevron techron 12oz. bottles in the tank today (put them in with 1/8 tank left then filled up). And I just got couple of fel pro TB gaskets in today so I plan on cleaning the TB this weekend also, not sure when the next time I will fill up is going to be, most likely early next week again.
im gonna do mine in the morning, so you think the longer it sits the better eh. I will let mine sit 2-3 hours. i'll let you know how it goes.
________
Lovely Wendie99
________
Lovely Wendie99
