trans fluid change question
how important is replacing the trans filters? one shop states that flushing the system through the cooler lines is more than adequate. another said it is a waste of time to replace the fluid without changing the filters. if i drop the trans pan will the fluid in the torque convertor drain out or am i going to get some 6 qts?
