Axle/axle shafts cause vibration?
#21
my vibration / shimmy was in the steering wheel = out of balance tires (new tires solved that problem) My vibration in the seat of my pants was a rear u-joint....this is all while driving. If it only does it while braking, then thats a whole nother story....(warped rotors, drums, etc). I DO have a vibration sometimes when braking at high speeds, but this is the typical brake shudder these trucks have (TSB aside). I can let off and brake again and it goes away. It only does that sometimes though.
#22
How intense was the vibration from your bad u-joint? Mine will rattle a tape measure in the door pocket or a full water bottle in the cup holder. I do hope it is a u-joint....that would be cheap and easy. The vibration started about 6000 miles ago (at appox. 60,000) and has progressively worsened.
The vibration is NOT felt in the steering wheel. Tires are brand new as of this past Friday and there was no change in the vibration between the worn Goodyears and the new tires.
#24
Also there are no squeaks or chirping.
#25
Sometimes it's in the steering wheel, sometimes the seat vibrates sometimes the whole truck vibrates.
My truck makes zero squeaking or chirping noise. Rode along the side of the truck when it was being driven from 0-60-0.
I have no clue. I am getting new tires in a couple of weeks after putting it off all summer.... I'll see if it really is the tires
#26
Just to jump in here with you guys, I have had the same problem for a while. I went to the dealer again recently. They kept it for 3 days, service advisor told me they swapped out my wheels and driveshaft with a vehicle on the lot and nothing changed. I'm throwing in the towel and just living with it. Maybe i'll figure it out by accident some day.
#27
Obviously if it fixes it, I will let everyone know.
#28
My guess is going to be the rear brakes, specifically the Ebrake return spring.
When you get the vibration, pull over and set the Ebrake, then release it and take it for a spin.
They upgraded the shoes/spring kit/drums in 2006 (late). I bit the bullet and had the dealer replace everything when the rear was being replaced (no additional labor for me, just the friggin $200 kit).
Vibration GONE FOR GOOD (over 9 mos, no issues up until the day I traded her in).
