what do you use for fog lights
Old 09-20-2013, 12:38 PM
Greatrack2012's Avatar
Greatrack2012
Greatrack2012 is offline
Originally Posted by jkeaton
I put HID's in my fogs. Plug and play. Less than $30 for the set. Light up the road like no other. Nevrr had people flash me either. They are set low enough that they don't blind oncoming drivers. But Dakotaff is correct, a standard 9145 bulb can be had cheap. Dealer will rip you off, just go to a parts storte, walmart, or get them off ebay.
ya I try to stay out of there. If you don't mind me asking were would I find a set of these HID's
Originally Posted by northgator8
I just did both of mine - used Silverstars so a little more expensive - replaced both so that they matched and when one goes, the other follows!
Just glad they are not as difficult as the headlights on my wife's volvo.
D
ya didn't take long for the other one to go
Old 09-20-2013, 02:13 PM
jkeaton is offline
Dodge Forum Administrator
Ebay or any other online HID retailer. Just google 9145 HID. Plug and play. No relays or anything else needed. These are the ones I got, just specify 9145 bulb size and what color you want.
http://www.ebay.com/itm/HID-Kit-Xenon-Headlight-H1-H3-H4-H7-H11-9004-9006-9007-/270407261624?pt=Motors_Car_Truck_Parts_Accessories&hash=item3ef5875db8&vxp=mtr#ht_4688wt_1279
Old 09-20-2013, 03:08 PM
Greatrack2012
HID Kit Xenon Headlight H1 H3 H4 H7 H11 9004 9006 9007 | eBay
Awesome thanks
Old 09-20-2013, 07:37 PM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Dodge Forum Moderator
Actually, for a 2010, they are not a 9145 bulb.
In 2010 (and consequently for the 2011 model year as well), Chrysler changed them to a PSX24W. Its a proprietary bulb originally made by Philips, very similar to a H16 (9009) bulb. The only two I've ever seen actually make it so far are Philips and AC Delco. They just moved the tabs around and decreased the wattage. I believe H16s are usually around the 35w mark... PSX24W are 24w.
You can order PSX24W bulbs online from Amazon for about $11 per bulb, or modify a H16 to fit. However, I would not recommend a halogen H16 bulb, as the computers are supposedly sensitive to how much wattage is sent down there. I've seen on other forums some people have reported their PCMs being fried.
One alternative is to buy H16 LED bulbs. Very cool look. I have tried a few and can make recommendations if you like. I ended up not going that route, as I could not get HIDs to work in 2010 housings, and I want my fog light and headlight colors to match (I am picky like that).
Last edited by jasonw; 09-20-2013 at 07:41 PM. Reason: Added info about LED bulbs.
Old 09-20-2013, 07:49 PM
Greatrack2012
oh ok good thing I haven't ordered the HID's yet was gonna do that later tonight.
Any recommendations would be great thanks
Old 09-20-2013, 09:19 PM
dakotaff's Avatar
dakotaff
dakotaff is offline
It's funny, I pulled the 9145 bulb out of a 2010 Dakota Owners Manual. They should get their info correct.
REPLACEMENT BULBS
LIGHT BULBS – Interior Bulb No.
Dome Lamp . . . . . . . . . . . . . . . . . . . . . . . . WL212–2
Cargo Lamp . . . . . . . . . . . . . . . . . . . . . . . . . . . . 921
Overhead Console Lamps. . . . . . . . . . . . . . . . . . . 192
Reading Lamp . . . . . . . . . . . . . . . . . . . . . . WL212–2
LIGHT BULBS – Exterior Bulb No.
Headlamp . . . . . . . . . . . . . . . . . . . . . . . . . . . . . H13
Front Park/Turn/Side Marker . . . . . . . . . . . . 3157NA
Back-Up . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3157
Center High Mounted Stop Lamp . . . . . . . . . . . . . 921
Fog Lamp . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9145
License Plate Lamp . . . . . . . . . . . . . . . . . . . . . . . 168
Rear Tail, Stop, Turn Signal. . . . . . . . . . . . . . . . . 3057
Old 09-20-2013, 09:23 PM
jkeaton is offline
Thats what I was thinking....
Old 09-20-2013, 09:57 PM
Greatrack2012
REPLACEMENT BULBS
Ya that's weird. I kinda thought the bulbs I was looking up were a little weird looking at the socket. Someone should really change that at Chrysler.
Old 09-20-2013, 11:11 PM
jkeaton is offline
Pull a bulb and confirm for us please.
Old 09-21-2013, 01:48 AM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Trust me, I was confused at first too. My manual states the same thing, 9145 fog bulbs. Those are the first bulbs I bought when I went to replace them. Ended up returning them.
I have pulled the bulbs out three times to try different LEDs. I even had to replace the passenger side wiring harness/socket initially because it was damaged and wouldn't disengage from the original factory bulb.
When I discovered this, I did a lot of research. Turns out Chrysler made some changes around that model year to save money. They switched a lot of different cars/SUVs to the PSX24W bulbs in 2008, 2009, and 2010. I believe I read about the Chargers having this change made, and some Jeeps. Its a cheaper bulb, but mostly because it doesn't generate the heat a 9145 bulb does due to its lower wattage. This in turn means the fog light housings don't have to be as strong, because they don't have to take as much heat. Weaker housings = cheaper housings.
Greatrack2012, go ahead and pull a bulb and show us. I am hoping I am wrong and you have the nicer 9145s, but I am pretty sure I am correct.
Here is an example of a PSX24W. These are exactly what I ended up buying on Amazon.
And an example of a 9145.
Quick Reply: what do you use for fog lights
