Looking to purchase a passenger airbag occupancy sensor light
Old 05-02-2016, 09:31 AM
xNeed6SpeedX's Avatar
xNeed6SpeedX
xNeed6SpeedX is offline
Default Looking to purchase a passenger airbag occupancy sensor light
Looking to get a replacement sensor light (the one located in the center console that turns on and off when passenger in the seat "located between the two vents) if you know what the part number may be. It no longer turns on at any point and believe it may be why I can't clear my airbag code. Thanks.
Old 05-02-2016, 09:34 AM
jkeaton is offline
Dodge Forum Administrator
Dealer.
Old 05-02-2016, 11:20 AM
dakotaff's Avatar
dakotaff
dakotaff is offline
Have you had the Airbag code read?
Old 05-02-2016, 09:40 PM
xNeed6SpeedX
So codes came up as
-U0184 (lost communication with radio) <--- have an aftermarket kenwood
-B212C (Ignition run/start imput circut open)
-B1206 (pass air bag indicator circut open)
-B1204 (pass air bag ind circut low)
Also the original owner had installed an alarm system and after purchasing had noticed the poor snip and stitch job he for some reason did to the indicator light wiring (will send pics in a minute) there is a purple and white wire (still connected) and a red wire (no longer connected) however it worked fine like that unitl i removed the old radio.
Also I bought a code read/clear so are these above codes usually clearable?
Lastly because I have the dash will a continuity check on the actual sensor light be able to tell me if i need to replace that little sensor? Found the part code to be 56043285AB and it is $50 >
Old 05-02-2016, 09:45 PM
xNeed6SpeedX
Quick Reply: Looking to purchase a passenger airbag occupancy sensor light
