Lifting the 3G Durango
Found a pic of a leveled Durango on this site.. Looks really good IMO. Those tires looks awesome as well... I'll be doing this soon.
http://www.suspensionconnection.com/...eling-kit.html
I'd like to know if that size would fit as well without rubbing or a lift. I've been trying to figure out what the biggest size tire I could get and not have it totally mess with performance. Hmmm. Would be great if someone more knowledgeable than me could chime in. Thanks
Definitely interested in leveling and possibly llifting the Durango a little.....I'm too tall and feel like I'm getting into a car instead of an SUV. Love the handleing compared to my previous aspen but miss the height of my aspen.
Well after speaking with not the company mentioned previously but with rocky road.com the fella has mentioned to me that I can now put on after a leveling kit 31" tires and no need for spacers. The lift kit for 2.5" can't be used on jeep grand Cherokees with the auto air adjustable suspension because you can't keep the vehicle at the raised height in anything above 15mph it will auto adjust downward and the bigger tires will then cause a problem. Also on the jgc you can fit 32.5" tires with the lift kit. Also some good news is that if we get a few people together for an order we can get up to 20% off our purchase.
The difference from what I understand is the rocky road leveling kit goes on top of the strut assembly requiring no disassembly of the strut itself. The Tuff Country requires a spacer in top of the spring which not only forces you to either buy or have the need to use an outside source to complete the job in which case making it more expensive and not a " 100% do it yourself " job. Second thing is that when you compress the spring in any vehicle it will change the ride qualities which some people may not have a problem with and most people will. The ride will be much stiffer compared to the Rocky Road adapter which leaves everything the same and just lifts the front. I'm leaning more towards doing the leveling kit versus the lift kit but the cutting of bolts in the strut assembly is what gets me because if you don't like the leveling kit you now have to buy these cheap 6 bolts from the dealership and have them pressed back in. No longer an inexpensive route if you decide to remove.
