Caliper clearance help.
no one mentioned this yet, but the HAT on the brembo rotors is lower profile then the stock durango ones, Your wheels will sit closer to the calipers then they currently do with the brembos.
When i put on my spider monkeys my car had some crazy wide stance that i disliked, with the brembos on, they got back closer to the car and less wide.
the brembo calipers are also MASSIVE. maybe try to find a srt to mount your wheel on hah.
didn't get any measurements, but it is a small amount, maybe 5mm, there was some other posting about this somewhere as well, but i forget where.
Well then again they are both the same height.
http://www.napaonline.com/Catalog/Ca...960_0400421487
Part Number: UP 880960
Product Line: NAPA Ultra Premium Brake Parts
Attributes:
# of Bolt Holes : 5
Bolt Circle Diameter : 5"
Brake Rotor Diameter : 14.96"
Height : 2.15"
Mounting Type : Type K - Rotor Only. Wheel Studs Are Pressed Into The Hub Only. The Rotor Is A Loose Fit On The Hub & Is Retained By Either Machine Screws Or The Wheel Nuts. See Diagram For More Information.
Vented / Solid : Vented
http://www.napaonline.com/Catalog/Ca...870_0400421365
Attributes:
# of Bolt Holes : 5
Brake Rotor Diameter : 13.78"
Center Hole Diameter : 2.84"
Height : 2.15"
Brake Rotor Discard Thickness : 1.201"
Brake Rotor Thickness New : 1.260"
Maximum Lateral Runout : .002"
Attributes:
# of Bolt Holes : 5
Height : 2.15"
Attributes:
# of Bolt Holes : 5
Height : 2.15"
