3rd Gen Durango 2011+ models
Replacing a turn signal bulb
Old 09-11-2014, 09:41 PM
harv1234's Avatar
harv1234
harv1234 is offline
Default Replacing a turn signal bulb
Just replaced a rear turn signal bulb. Used the link below as a guideline. Dealer quoted me $37.50 CDN (bulb warranty is only good to 20,000kms here and I'm at 30K). I paid $6.27 CDN for the bulb and it took less than 10 minutes. I expect the next will take less than 5 minutes.
Dealer gave me the bulb without packaging so I wiped it down pre-install and used a Kleenex to handle it to avoid finger oils. I also used a small slot screwdriver to pry out the plastic snaps and a large slot with a rag to pop the housing out of the body so I didn't damage the paint.
Anyway, hope this helps.
http://www.carcarekiosk.com/video/20...hts/tail_light
Old 09-12-2014, 12:38 PM
mcfarl58's Avatar
mcfarl58
mcfarl58 is offline
You should specify that this was not on a 2014. 2014 Durangos are just as easy and the same process, but much more expensive.
Old 09-12-2014, 06:59 PM
harv1234's Avatar
harv1234
harv1234 is offline
Sorry, thought my tagline explained my year. Why is a 2014 so more expensive?
Old 09-12-2014, 08:07 PM
mcfarl58's Avatar
mcfarl58
mcfarl58 is offline
LED. And when I replaced my broken tail light, it didn't look like there was a bulb that could be removed. You have to replace the entire light itself. That's $400.
Quick Reply: Replacing a turn signal bulb
