Not enough power
RIPP makes one with truely impressive gains...we're talkin SRT8 type gains.
Everything else pales in comparison and will not net huge results...but they will get you some results.
The rear end gearing is pretty tall as well, what?...3.09s.... So its not gonna geat real quick, real easy or real cheap.
One thing you can do on your own that may improve the acceleration "feel" is to learn to shift it manually.
Good luck.
...as I think about it now, it might just be that the throttle isn't as aggressive...
n
http://buyersguide.caranddriver.com/...o/specs/353193
I just checked the build sheet for my 2013 Crew with the 5.7L and it has the 3.45 rear axle ratio.
That can be easily fixed with an inTune DCX tuner. The Durango is designed for less spirited driving than is a sports sedan, the former has a "gentle" throttle for the soccer moms etc. The inTune will fix the lagging throttle, change upshift points for more lively driving around town, etc. No intake, exhaust, etc will do as much for the $$$ spent. Get one.
n
n
Absolutely setup stock for a Soccer mom grocery shopping, not the Bonfire scene in Breaking Bad with Walt and Walt Jr's Hemis.
n
n
Diablo DCX and Edge racing 3200 stall torque converter. Thats all you need unless youre trying to impress the internet. The Superchargers are making good power but give them 10k miles and lets see how durable its been to forcebly add 50% more power rather than extract the power thats available. Also those are using a centrifugal blower aka no high power unless really revving it out.
