View Poll Results: What kind of lowering kit do you have>
McGaughy's
28
54.90%
DJM
5
9.80%
Ground Force
10
19.61%
Belltech
5
9.80%
Other(post in your reply)
3
5.88%
Voters: 51. You may not vote on this poll
Lowering kit
Old 12-18-2010, 05:26 PM
GREENandSILVER95's Avatar
GREENandSILVER95
GREENandSILVER95 is offline
i just got my mcgaughys 2/4.5 kit in today, shouldnt it come with shackles for the rear? the end of the box was damaged and im just trying to make sure i have or havent lost anything. Also do you need a cnotch when when you lower the rear this low and pull a trailer?
  #22
Old 08-03-2011, 08:27 AM
06 RRD Ram's Avatar
06 RRD Ram
06 RRD Ram is offline
McGaughy's makes some of the best suspension parts out there. They are fairly inexpensive compared to some of the other kits. My 2/4.5" drop came with the coils for the front, but i am debating on putting the stock coils back in and putting the 2" drop spindles on instead.
  #23
Old 12-02-2011, 02:40 AM
V10Venom's Avatar
V10Venom
V10Venom is offline
Can someone provide me a link to what I would need to just drop the rear 2"?? Thanks
  #24
Old 12-10-2011, 02:17 PM
MD87's Avatar
MD87
MD87 is offline
im running the Mcgaughys 2"/4.5" and i like it so far. i am running the srt-10 wheels with a 305/45R22 and have the bell tech nitro drop 2 shocks on order.
  #25
Old 04-30-2012, 09:29 AM
Sinister1JP's Avatar
Sinister1JP
Sinister1JP is offline
Belltech 2/5 drop, with Airlift helper bags and 24's with 305/35's
Attachment 16101
  #26
Old 08-19-2012, 08:21 AM
Jacob Boyd Bauer's Avatar
Jacob Boyd Bauer
Jacob Boyd Bauer is offline
with the groundforce kit, how does that work on installation? because it seems to me that you would need to change the leaf springs out also, and not just the rear shocks.
  #27
Old 10-21-2012, 12:24 AM
motoservdog's Avatar
motoservdog
motoservdog is offline
I have the McGaughys 2/4.5" with coil springs up front. I am riding on the front bump stops. To the people that have the same kit, did you cut the bump stops and install shorter ones? Or did you just not install bump stops after cutting them, or just left them alone?
  #28
Old 10-23-2012, 05:10 PM
revpete's Avatar
revpete
revpete is offline
I have a 95 Ram 1500 short box 2wd. was lowered when I got it.. Front is too low, lower a-arms scrape on real rough surfaces or driveways. Rear sets fine. looks like it was just a rear end swap from bottom of the springs to the top side, dropping it (what? 6 inches?)
Someone help Please!!!
What do I do. I want to level it out.
Thanks
Jeff
Quick Reply: Lowering kit
