View Poll Results: What brand body lift do you have?
Performance Accessories
48
78.69%
Top Gun Customz
2
3.28%
Rough Country
8
13.11%
Other(post in reply)
3
4.92%
Voters: 61. You may not vote on this poll
Body Lift Kits
Old 05-05-2010, 08:07 PM
SEBDodge's Avatar
SEBDodge
SEBDodge is offline
Originally Posted by 12elentless
i must emphasize this is a VERY easy install. however, youll need
-floor jack
-4x4 block of wood (to put between jack and cab to stop dents)
-dremel
-welder if you want to tack in bed spacers
-hand tools
-couple friends is nice.
-Cutting wheel for frame horns and frame brackets.
also, ONLY DO ONE SIDE AT A TIME. this will save you tons of time youd spend lining up, redoing, etc. Loosen one side, unbolt other, repeat, tighten.
i don't have access to a welder are the bed spacers necessary?
  #32
Old 06-15-2011, 10:01 AM
BWhelan's Avatar
BWhelan
BWhelan is offline
It's my understanding that the weld is not necessary but the bed spacers definitely are if you want it to look right. (Or else you bed will be inches lower than your body...
  #33
Old 06-15-2011, 12:16 PM
12elentless's Avatar
12elentless
12elentless is offline
Doesnt know what hes talking about.
The welding they speak of is the flex protectors that go between the frame and the bed itself. it doesnt lift the bed at all, it just keeps the bed from sinking in the center if loaded. The actual bed spacers are on the four corners of the bed. These are in the center.
I never welded mine in, i just slid them in place, and they were snug enough never to rattle out.. and i used mine as a truck quite a bit.
most people that use a body lift arent gonna be hauling 2 tons of brick in their beds, but still. welding isnt required, nor is the fuel filler extension, or the steering stem extension. Theyre recommended, but youre not gonna die if you dont. ive installed several bls and ive never done any of them.
So to answer your question, no, you dont "need" a welder, you can just snug them in and youll be fine. next time youre at a muffler shop have them tack em in for $10 if youre really worried. Theyre in plain sight if you dont have gap guards so itd be a 10 second job.
btw, my old truck is for sale again if anyone wants it.
  #34
Old 08-30-2011, 10:03 AM
xtrem241's Avatar
xtrem241
xtrem241 is offline
Default New dodge owner here
I want to do a lift on my 02 QC. I have been reading on this site about the
3 in pa body lift .. I was just wondering if I went to the 5 in PA body lift
in the future could I still run a suspension Lift with no issues ? for instants a rough county or a skyjacker or fab-tech ?? The reason I ask is The standard 3 in is around 400.00 the 5 in is around 540.00 so my thought is if I can get an extra 2 inches for 150.00 dollars why not ? Please advise
http://www.summitracing.com/parts/PRA-PLS600/?rtype=10
  #35
Old 09-12-2011, 04:55 PM
12elentless
holy hell. please dont do a 5" body lift.
  #36
Old 09-13-2011, 01:05 PM
xtrem241's Avatar
xtrem241
xtrem241 is offline
They don 't even make a 5 in Body lift... I was referring to the
5 in lift that PA makes .. 3in body 2 in front spacers .. (my bad for (misswording)
anyhow I got it all figured out now .. and to answer my own question
for a future install of a suspension lift .. Yes the spacers would have to be removed. so it would not be advantageous to spend the extra money if they are going to be removed.
  #37
Old 05-01-2012, 08:07 AM
JGreen273's Avatar
JGreen273
JGreen273 is offline
For those that have done the 3 in. PA BL, does the front end still sit lower than the back? If so is it possible to install a leveling kit after the BL? Thanks!
  #38
Old 05-01-2012, 09:26 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Yes you can still level the front after body lifting the entire thing
  #39
Old 08-08-2012, 02:14 PM
Nate_sorenson's Avatar
Nate_sorenson
Nate_sorenson is offline
ive had this bl in my room for 3 weeks now and i went into the only thinkable place who would install it (performance truck accescories) and they gave me a big fat no on installing it. Im not very mechanically informed so I have fear of delving into this project. Can I try and see if a dealership will do this?
  #40
Old 03-21-2015, 11:10 AM
baffled's Avatar
baffled
baffled is offline
I have an 05 ram 1500 Laramie .... I was told by the local off road shop that because my year/model ram is equipped with torsion bars that installing new torsion bar keys even to just level the front would screw up the way it drives and would cause me tire wear problems..... any truth to that?
Quick Reply: Body Lift Kits
