View Poll Results: What temp thermostat you runnin!
Stock
144
68.57%
180 t-stat
60
28.57%
160 t-stat
4
1.90%
Other(post in reply)
2
0.95%
Voters: 210. You may not vote on this poll
Thermostats
Old 03-25-2010, 01:50 AM
JoeHemi's Avatar
JoeHemi
JoeHemi is offline
I just put in a new Murray stock temp thermo. I enjoy having heat and no gunk buildup
  #22
Old 03-27-2010, 11:09 AM
FireFighter's Avatar
FireFighter
FireFighter is offline
What is the stock temp stat rated for? I just bought one at Advance to replace existing, it's made by Stant (xactstat) says 203 on the box.
  #23
Old 03-27-2010, 02:40 PM
JoeHemi's Avatar
JoeHemi
JoeHemi is offline
my old one was a 203 which I believe was the factory stat and I replaced it with a 203. Coolant generally runs between 201 and 208 while I'm driving now. I did a coolant flush when I changed the stat and it was all at 130,000 miles. The stat was working fine, but I just did a little preventative maintenance just to be sure it stayed that way.
  #24
Old 03-27-2010, 03:02 PM
FireFighter
Thanks Joe. Yep, doing the same here today, stat, fresh coolant and total flush of system.
  #25
Old 03-27-2010, 10:48 PM
RedTruck-VA's Avatar
RedTruck-VA
RedTruck-VA is offline
Just got the Jet 180 and efan today. Hope to have them installed tomorrow.
  #26
Old 03-30-2010, 09:18 PM
04_ramslt's Avatar
04_ramslt
04_ramslt is offline
Hey joe how did you flush the entire system?
  #27
Old 03-30-2010, 10:05 PM
FireFighter
I also drain the block, the block drain plugs are above the oil pan and there are two, one each side. Then flush it. I remove t-stat housing, remove t-stat, replace the t-stat housing, remove upper radiator hose. I flush with garden hose in upper radiator inlet until it runs clear out of the end of upper radiator hose. Install in a new t-stat.....and continue with remainder of this fun project.
  #28
Old 03-30-2010, 10:58 PM
JoeHemi's Avatar
JoeHemi
JoeHemi is offline
I did mine the easy way. I took it to my uncles shop lol. He's got a flushing machine where you hook it up to the coolant lines and it runs for about 5 minutes flushing and cleaning out the old coolant in the system. I bought 3 gallons of Zerex G-05 coolant from the local napa store. The machine dilutes the coolant 50/50 and keeps the air out of the system while refilling the system.
  #29
Old 03-31-2010, 07:20 AM
FireFighter
Now that's just too cool, I want one of those.
  #30
Old 06-28-2010, 10:08 PM
haulinhemi06's Avatar
haulinhemi06
haulinhemi06 is offline
put my 180 in a few months ago. keeps the ol hemi runnin nice and cool.
Quick Reply: Thermostats
