RAM 1500 hemi engine removal
Old 03-15-2008, 10:51 AM
tmodlin's Avatar
tmodlin
tmodlin is offline
Default RE: RAM 1500 hemi engine removal
Tranny out the bottom and lift the engine out the top. Going to need a tall cherry picker though, damn trucks sit so high. A ceiling hoist would be nice too.
Old 03-15-2008, 11:18 AM
Horseapples's Avatar
Horseapples
Horseapples is offline
ORIGINAL: tmodlin
When you are ready to remove the engine, remove the front tires and lower the truck on your floor jack. Wood blocks under the rotors will prevent ant damage if you accidentally set it all the way on the ground. Works like a charm on lifted/tall vehicles!
Old 03-15-2008, 11:50 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
SeVeReDiStOrTiOn is offline
ORIGINAL: matthew11224
lol just experimenting no just doing work on it with a friend of mine but i want to learn to take it out on my own
You wanna pull it for ****s and giggles? If you just want to tinker with your truck then do a cam swap and have the heads P&P'd....at least there will be a point and you'll see a huge gain.
Quick Reply: RAM 1500 hemi engine removal
