Right Power window only works from driver's side
Old 06-17-2010, 06:54 PM
motionb's Avatar
motionb
motionb is offline
Okay, my 03 Durango is fixed, it for sure was the red wire, well not the wire but the connector on the control panel where the red wire plugged into, it had a bad connection, I had ordered on Ebay a replacement window control panel, once I replaced it, it all works now, before I replaced it, I could close the driver door or just jiggle the red wire and all the other windows would quit working, then I would just jiggle the red wire again and they'd start working again. I replaced the control panel and everything works correctly now, so mine wasn't the wire but the connector itself on the control panel, hopefully this helps somebody.
Thanks
  #22
Old 02-01-2011, 01:46 AM
ramjamhemi's Avatar
ramjamhemi
ramjamhemi is offline
deleted
Quick Reply: Right Power window only works from driver's side
