3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I have the same issue on a 2001 Dakota 4.7L Quad cab. The truck starts up and is fine, with no dummy lights. Then after a mile or two the ABS light comes on with the brake light. I have a few things to try, but I wish there was a better way to isolate the problem. If you plug into an obd sensor will that shed some light on the issue?
Take it from me, the lamp may very well be coming on for a true problem. My wife drives a 2006 G Caravan, and last year the brake lamp would come on and off intermittently. It turned out to be a bad wheel bearing. So, have it checked out if the problem does not go away.
had the same problem with my endied up being 3 problems, bad driverside front wheel bearing, bad driverside front abs sensor and bad rear abs sensor, the one on the dif
Yea that sensor is in a bad spot with no protection. Burry the truck once up to the diffs in mud or snow will almost for sure cause troubles.
