Rear door locks not working
It certainly could be the actuator. While I cannot really diagnose over the forum, the actuator may be the problem since it is only one door having the issue. Just wanted to make sure that if there is a TSB or recall on an issue that I post it in case it can help solve the problem. It's always a good place to start and if others are searching for the same issue they can be made aware of the TSB even if it didn't solve your issue. Sorry I could not be of more help.
I just bought an 04 Ram1500 QC and didn't even notice the power door locks not working properly until 3 days later. The 3 passenger doors will unlock but not re-lock with either the fob or in door button. I checked both back harnesses and cables and found no breaks. Also the driver lock sometimes wont unlock completely(rise enough to allow me to open the door) I have read that maybe it's the instrument panel???
Can someone please help?
It's weird how it's usually the wires in the back doors that break apart first. Are they a smaller gauge than the front wires? You would think that the wires in the drivers door harness would be the first to go (unless they are a heavier gauge). 75% of the time it's only me in the truck, rarely do I have more than 1 passenger, yet I have a few broken wires in both back doors.
as for the previous post, I am unsure. Its weird that all doors barely have enough power to lock and unlock, if it was just one i would say its the lock actuator in that door but i doubt thats the problem if all 3 passenger doors do the same thing and sometimes the driver door. Props for searching though, hope someone can help ya.
i have a 2006 4 door dodge ram. about a year ago one rear door lock stopped working and now just recently the other rear door lock has stopped working.. i have searched the forums without finding the same exact problem.. the only fuse i could find for the door locks works all four of them and when i take the fuse out the front locks stop working when i put it in the front locks work again. they don't work with the fob for keyless entry or the switch on the driver door.. thank you for any help
