sqeaking sound while turning what could it be?
Old 07-03-2015, 04:14 PM
swamper's Avatar
swamper
swamper is offline
Question sqeaking sound while turning what could it be?
my truck has been making a loud sqeaking sound from the front drivers side when I turn its now getting pretty loud.my upper ball joints are all new but the bottom ones are old so what could it be?
Old 07-03-2015, 10:40 PM
p38251's Avatar
p38251
p38251 is offline
Lower ball joints tie rods. Upper lower control arm bushings
Old 07-04-2015, 01:51 AM
swamper's Avatar
swamper
swamper is offline
ok the tie rod ends are new but the inners are old guess I got some things to check out.thanks 4 the info.
Old 07-04-2015, 05:47 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
Lift the front and go to shaking. Something will have excessive play, unless you have an issue with the rack...
Old 07-07-2015, 04:31 PM
swamper's Avatar
swamper
swamper is offline
turns out its the lower front control arm bushing I sprayed silicone on it and its still making the sound.Can I spray catalyst spray on a rubber bushing or no?
Old 07-08-2015, 09:18 AM
SmokinJoe02's Avatar
SmokinJoe02
SmokinJoe02 is offline
Use white lithium grease.
SJ03
Old 07-08-2015, 06:18 PM
TejasMtnBiker's Avatar
TejasMtnBiker
TejasMtnBiker is offline
limited slip making noise like that?
Quick Reply: sqeaking sound while turning what could it be?
