Stalling Issue on '06 5.7
Old 08-30-2015, 01:53 PM
Reddevil13's Avatar
Reddevil13
Reddevil13 is offline
Default Stalling Issue on '06 5.7
I have a 2006 5.7 Hemi Aprox 150,000 miles
Recently it began stalling at idle, while in park, drive, neutral, reverse.
also stalls while driving at low speeds, when let off the gas, not all the time, and there seems to be know pattern to when or why it stalls, however turning the Air Conditioner on, seems to make it happen more often. also noticed it happens a lot when turning to the left.
DTC's that were Present:
(2) P0300: Random Misfire
P1521: Incorrect Engine Oil
P0315: Crankshaft Position System Variation not learned
Since the Stalling occurred, i have;
-Replaced the Crankshaft Position Sensor (and run the Re-learn )
-Replaced the Throttle Body Unit
=Replaced Camshaft Position Sensor (under the advisement of dodge)
Now the truck will not stay running at all, unless reved to 2500 RPMs and is throwing the following codes:
P0007
P0004
Any help or advice anyone could offer, would be fantastic
Old 08-30-2015, 02:47 PM
p38251's Avatar
p38251
p38251 is offline
Random misfire. Plugs, wires, PCV clean throttle body. Can of sea of sea foam in the tank. Incorrect engine oil is self explanatory. This could also cause mds system not to operate correctly.
Old 08-31-2015, 02:43 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
I've only seen the P0004 and P0007 on diesels myself. And there they are indicative of bad fuel (water) taking out the fuel pump and fuel shutoff valve...
Quick Reply: Stalling Issue on '06 5.7
