Says first but actually stuck in Park
Okay I have to say thank you for all the help in the past. But I can't find this answer on here.
Dodge Ram 1500
I just swapped out my PCM because my TCM was bad. I had it re flashed and drove it home. A code threw so I changed the Transmission pressure sensor because it was bad. Initially I thought it was located in the tranny pan so I dropped it and found out I was wrong. When I went to start my truck it said it was in 1st gear per selector on dash. The snifter moves freely up and down not engaging at all in any gears. However the key will turn but all I get are my lights, radio, and dash lights. No starter clicking at all. It is throwing a code but I can't read the code because it is not in park. I have the 45RFE transmission. Thanks for the help in advance.
Dodge Ram 1500
