Mega Cab RPM, what are you getting on the highway
Old Feb 9, 2012 | 10:33 AM
SgtCortes's Avatar
SgtCortes
Default Mega Cab RPM, what are you getting on the highway
Greetings fellow Ram owners, just laid to rest my 2002 Dodge Ram Quad with the 5.9L, 4x4 on 35s (gonna miss her) and I purchased a 2007 Dodge Ram Mega Cab with the HEMI (only 29K miles). So I have a couple of questions on this truck.
I read that we don't have the MDS, but what RPMs should I be seeing at freeway speeds, mostly around 70mph. I am at almost 2k on the RPM and I was usually at about 1600 RPM on the 5.9L. So just wondering what RPMs are you guys getting with the HEMI at FWY speeds.
This is a stock truck, 2wd with CAI.
thanks
Old Feb 9, 2012 | 11:50 AM
Arctodus's Avatar
Arctodus
At 70 mph I am at 1800 rpm, but I also have 35" tires. It also depends on what gears you have. I have 3.73"s which is most likely what you have.
Old Feb 9, 2012 | 02:10 PM
extremis's Avatar
extremis
Close to 2000 on mine. 4.10 gears, 285/70/17 tires. I think that is sort of the normal range. May also depend on whether there is slight grade or not (torque convertor engaged or not).
Old Feb 9, 2012 | 09:22 PM
pitbull24's Avatar
pitbull24
Your probably looking for numbers on similar trucks, but with 4.56's and 38" tires I don't see 70mph too often as i think i get negative gas mileage up there. jk.
IIRC I'm around 2400-2500.
Old Feb 9, 2012 | 09:36 PM
dirtydog's Avatar
dirtydog
Moderate User
MDS doesnt lower rpms just so you know. RPMs stay the same in equip Rams.
I have altered my transmission so I get higher rpms at all speeds. It increases performance by keeping the truck within its powerband and it actually improves mpg's! Ofcourse by 70mph, my truck is in 5th and I am at 1850rpm with my stock 3:73 gears. Use of a Superchips tuner with Advanced trans tuning to alter shifts.
The Hemi has 100HP more and still gets better mgps than the 5.9L so your already ahead!
Old Feb 9, 2012 | 10:22 PM
SgtCortes's Avatar
SgtCortes
Thanks. Different truck, different motor so wasn't sure where the RPMs are yet...
I have the 3.73 gears...
PS... Drives like a champ and so much more power compared to my old one.
Attached Thumbnails Mega Cab RPM, what are you getting on the highway-tk.jpg
Old Feb 9, 2012 | 11:03 PM
gcburkett's Avatar
gcburkett
Looks like you have 245/70r17 tires on the truck. That would give you 681 revs/mile.
681*3.73*.67*(70/60)=1985 RPM. A 35" tire would be around 576 revs/mile. If you had those 35" with a 3.55 axle. 576*3.55*.67*(70/60) =1598 RPM.
You old truck was really gear pretty high. Most people would want at least the 3.92 or higher for 35" tires.
Old Feb 10, 2012 | 11:50 AM
Arctodus's Avatar
Arctodus
HOLY STINKBUG, you need a leveling kit Srg. Haha
Old Feb 10, 2012 | 12:47 PM
PhillyFireLieutenant's Avatar
Default rpm's
2200rpm's at approx 63mph to 68mph...
