RRT Description Thread
lets post this info in the faqs section
https://dodgeforum.com/forum/4th-gen...-and-rrts.html
That way we have a 1 stop spot for all RRT's
My MDS doesn't come on as often. The update did change the clock as well as the engine hours (the one that counts hours minutes and seconds not the other that just shows the hours). That's probably due to having to reset the system. I am a little upset that it seems to have messed with the MDS.
no question it is "learning". it's been about three weeks since i had the MDS flash and the efficiency of the 4 cylinder mode is much better now than when i first had it done. it's also better than before the flash.
yes. for instance, the washer harness for early build 09 trucks is cut out, and install an overlay harness. new trucks have a revised harness, updated sensors, and such.
