Last edit by: IB Advertising
Browse all: Interior Guides
- Dodge Ram 2009-Present: Key Fob Problems
Important information to help you understand your Ram.
Cannot Remove FOB/Key from ignition on 2011 RAM 1500 (Battery Not Dead, Gear in Park)
#21
#22
2011 key FOB lock
Ghostdog....same thing just happened to me......a security malfunction occurs so it locks the truck functions for security, seems like dead key FOB or truck battery.....I checked 13.75V on both....interior lights work but nothing else......disconnect battery positive terminals for 5 min.....reconnect and start.
#24
#25
I've got this same issue repeating over and over, only for my 2011 ram Laramie, disconnecting the battery doesn't work and after reconnecting the alarm goes right back to work. This is the fifth time getting stranded, I'll lock my truck via fob return and, guess what?! The fob doesn't work anymore, no problem I'll just go back and buy new batteries for the fob, nope that doesn't work either. So then I manually use the key to open the door and proceed to have the funniest time of my life in a Walmart parking lot, horn blaring. Help, there's no way to disable the alarm mode both of my fobs have gone down, there's no choice but to tow to the dealer that isn't open. I'll post back with what they tell me - I know I can't be the only mf'r that this is happening to.....
#26
Welcome to the forum. Sorry to hear about your concern. Be sure to keep us posted on this!
#27
Solution to Key FOB stuck in ignition
2011 dodge ram 4x4 big horn.
What happened: My FOB would not unlock my doors so I used the key inside the FOB to unlock the door. As soon as I opened the dorms alarm went off. I tried to start the truck and it would not do anything. I tried to take the key out and it was locked, it would not turn all the way to off and was stuck.
Problem solving: Called dodge. They said tow it and we can run diagnostics for 150/hr. So I was looking at minimum $350-400.
Solution: DO NOT TOW TO DEALER! Disconnect your battery and let it sit. I let mine sit overnight. Turn your key to ACC. Connect your battery. You should hear 3 honks. Then start your truck!After that you should be good to go!
#28
Thank you!!
Sounds like the computer is confused. Perhaps it will be better after you disconnect the battery and leave it unplugged for 10-20 minutes. Then reconnect things and see if the system is back to normal and the key fob comes out.
Our 2005 Grand Cherokee went nuts once where it refused to unlock the doors with either key fob and then set off the alarm when I opened the doors with the actual manual key. The alarm would not turn off by any means - hitting the unlock button on the door nor starting it up. And even starting it up left it in theft mode so I couldn't drive it. Had to unplug the battery for a few minutes to reboot things. Was a real clusterfrack because this happened out front of a busy restaurant on a Friday night. Talk about embarrassing. Sometimes these computers just get confused.
Rob
Rob
Thanks again guys. If you are ever in the Topeka, Kansas area, look me up and I'll buy you a beer!!
