Mileage Improvements
Agreed. But aftermarket parts manufacturers throw the term "Cold Air Induction" around irresponsibly. They label anything that replaces the stock induction system (post Throttle body) as a Cold Air Induction even though it's drawing air from the engine compartment. These systems actually hurt performance but people who believe the advertising buy these systems and believe they are working.
You very well might see some MPG gains if you replaced the Throttle body and ported the heads. But when you think about the cost, massive amount of labor and instant voiding of the engine warranty you will realize that it is an economically foolish idea if the primary purpose is increasing MPG's.
The easier it is for the engine to breathe, the less the engine has to work. The less the engine has to work, the less fuel it uses.
Older vehicles used to see much larger improvements with simple bolt on's such as high flow intakes and exhausts. Restrictive intakes, single undersized exhausts, inefficient EFI systems, etc. I had an 85' Trans Am and that i replaced the intake runners, throttle body, airbox, injectors, headers and exhaust on. It was a TON of labor and money to get that extra power up to around 300hp. Now you can buy a Camaro that puts out more HP then i worked to get right off the showroom floor. In fact, my 85' 305 V8 TPI Trans Am from the factory was 215HP. The new Camaro's are putting out 323 HP in a V6 and getting 30MPG! So the car manufacturers are not idiots. The aftermarket parts companies are simply running out of ideas.
Car sales are heavily driven by the numbers. MPG and HP. Sure, people like features and appearance. But they also want as much power as possible using as little fuel as possible. So car manufacturers are doing a good deal of the simple mods the buyer used to have to do. So a lot of the mods are completely redundant. Like bolting on a high flow airbox on a 4th gen Ram. Even a Cat Back exhaust is a waste of money for HP or MPG gains on these trucks. You MIGHT pick up 1 MPG doing a cat back exhaust on an otherwise stock truck. But you will spend a few hundred bucks plus labor and have a noisier truck (which to some people is a downside) and have no exhaust warranty. So in the end, how long will it take you to recoup that investment?
Saying they're idiots, I'm not, but in the end vehicles are an investment, period.
So, there's always something that can be done to improve it. As you stated earlier, Port work, pricey yes, but this is one manufacturing flaw that can always use work due to casting flaws. Pricey sure, but that's a fact of owning vehicles and wanting to improve them.
How much have you spent on your trucks visual mods? They don't help anything but the looks, so how long will that take to recoup? So on that theory why even bother?
on
Sounds like it should be that way, but it's just words. The easier it is for the engine to breathe means more air for the combustion which means more fuel to keep the programmed Air/Fuel ratio. When you say easiest, you are being subjective but the actual effect on the engines ability to breathe is very objective and measurable and impact on MPGs is nil. As a matter of fact, may on this forum and many others have complained of reduced MPGs.
You are correct, fancy paint, emblems, fancy wheels and decals serve no purpose other then visual appeal.
