Building a custom sub box and amp rack!
Hertz Energy ESK 165L.5
THe down side to it is here the weather is turning and the cold weather is making it tough to work let alone work with fiberglass. So I am currently finishing running all the wire.
The problem that I am dealing with now is that I prefer to run new wire from the speakers and damn Dodge has these damn connectors in the all the doors that do not allow me to run my own wire.
So I am in the process of cutting all the connectors off to eliminate the connectors and then I am soldering the needed wires (pwr windows, locks etc) back together. This has been tedious to say the least. I'll post some pics shortly.
The down side to this is that I am not really going to be able to finish the amp side the way I wanted to until it warms up in spring. So all the amps will be temp. mounted to make the system functional,
Here are some pics I have not posted here yet. Should be ready for paint after all the damn sanding...did I mention I hate sanding. Fingers a raw....If I would have taken my time and fiberglassed better I would have not had to do so much sanding... Just have to filler prime it and wet sand it and then pic a color
theDogger
I don't see how me finishing it is stopping you from starting yours!
theDogger
